Central Electric Module
Old May 27, 2019 | 02:00 PM
jharvey3's Avatar
Default Central Electric Module
I bought a 2004 s40 1.9 . The left headlight low beam is inop. The previous owner thought it was the housing so they got an extra headlight housing. I testes the voltage going in and got .4v-5v. Tested the power from the fuse to the CEM and got batt v. Continuity from CEM was .01 ohms. I have narrowed it down to the power side of the relay within the CEM. Passenger lights and highbeams work just fine. I am considering splicing the left and right headlights together and upping the fuse by 5 to handle the increased current. I can use ohms law to estimate the current flow but bulb R can change with heat. I am just trying to pass inspection for now until I can find another CEM. If the new to me CEM is installed, must it be programmed?
Old May 27, 2019 | 06:50 PM
on the S40 1/9s the CEM does not need to be programmed. You will find it under the drivers side dash just above the hood release. You can probably get by with a used unit - I found one for $65 and its worked fine since.
not sure why the P/O got a whole new headlight housing - if there's an issue its with the connector to the bulb - the bucket itself is all plastic.
Old May 27, 2019 | 08:29 PM
jharvey3's Avatar
Thank you, ive found, tested and disassembled it to see if the relays were serviceable. I found that they were not so ive been looking for new ones in scrapyards but I cant find a 2000-2004. Found a few on ebay but hated waiting. I then saw ads to reprogram them and wasnt sure if that was required for this year.
Old May 28, 2019 | 09:33 AM
reprogramming is for the newer models, you can go with a used CEM or search for info on how to solder in your own replacement relays for the low beams
Old Jun 2, 2019 | 05:15 AM
Hudini's Avatar
If you are handy with a solder tool then just replace the relays.
Old Jun 2, 2019 | 12:01 PM
jharvey3's Avatar
I picked up one for $35 at a salvage yard. Ill plug it in and see if it works. If not ill crack them both open and replace the faulty relays.
Old Jun 5, 2019 | 07:46 PM
jharvey3's Avatar
Replaced the CEM and my ac/blower works fine now (had been going off and on) and lights work fine. The $35 salvage yard unit works for now.
Old Jun 6, 2019 | 12:03 PM
habbyguy's Avatar
jharvey3, thanks for the confirmation. That's bound to help others with similar problems in the future. Heck, I'm a techie, and really handy with a soldering iron, and there's no way I'd want to fiddle with trying to fix one if there's a $35 replacement option! Well played!
Alexis Covarrubias
Apr 21, 2019 11:41 AM
Lone3wolf
Mar 20, 2019 09:42 AM
Newport_j
Feb 21, 2019 04:13 PM
Scarlet
Feb 6, 2019 05:24 PM
Newport_j
Jan 11, 2016 08:06 AM
