changing transmission fluid
called volvo today for my 2002 sv40 turbo automatic
and asked for price for them to change transmission fluid $350 wow
they said due to being synthetic fluid
- is it a big job to change and i dont have a volvo manuel on me,,but if to buy how many quarts of transmission fluid
thanks
or maybe just let them change it
thanks
RE: changing transmission fluid
ORIGINAL: sherry
I ordered a case of 12 quarts from Mobil. I have a 2001 S40 with the 2/3 flareup going on. Are you saying this is not enough??
Just drain and fill, and run around the block to mix it up with the Torque converter. Do three times and you are good for 50K.
Only about 3.2 quarts come out during a drain, the rest is in the converter. I hope you will notice a difference after doing it. Good luck.
