Charger cigarette lighter fuse replacement
Old Jan 13, 2014 | 05:19 PM
Sueleigh's Avatar
Default Charger cigarette lighter fuse replacement
Hello,
I have a 2009 S40 volvo. Both the front and rear cigarette lighter (well basically just a voltage station) is no longer working. I'm guessing the fuse is blown because I have tried different chargers. Where is the fuse located, what type of fuse do I need to purchase, and how easy is the replacement? Thank you very much.
Old Jan 13, 2014 | 07:32 PM
damien360's Avatar
The fuse is located on the CEM. To get to it you will need to get under the passenger side dash. Under the dash there is going to be a cloth like cover. You will need to press up on the center of the 2 clips holding the cover. Once you have the cover removed you will be able to see the CEM. To get the CEM down you need to twist the 2 tabs that are holding it up. Once you got those off the CEM should drop down just a bit and you will be able to pull it down to expose the fuses. If my memory serves me right it should be fuse #45 and it is a 15 amp fuse.
Old Apr 14, 2025 | 11:07 AM
Asim Arif's Avatar
Default F45 ?
I have F45, is that the one?
Please see the pic.
F45
Shpoone
Jun 3, 2021 11:39 AM
Kalvis jasko
Sep 10, 2020 09:26 AM
fiey24
Apr 5, 2014 07:10 PM
alan - flitwick
Apr 14, 2009 11:04 PM
c70turbogt
Jul 11, 2007 04:33 PM
