check engine light on after getting air filter
Old Aug 17, 2008 | 04:40 PM
jordaninabox's Avatar
Default check engine light on after getting air filter
Hey I recently installed an APC performance air filter on my 2001 volvo s40 1.9t and once I installed it my check engine light came on, I am pretty sure its because of the cord I unplugged but am unsure what it does. Ive checked all my brakes and signals all of them work, maybe you can help me out.
This is what I disconnected
and I painted my grill black
and my rims
my ride
Thanks alot!
P.S. it sounds really good, you can hear the air getting sucked in and when you let off the gas it sounds quite like a BOV
Old Aug 17, 2008 | 06:36 PM
Default RE: check engine light on after getting air filter
That is the mass flow sensor you unplugged. The car needs it to run right. You need to remove it from the air box and put it back in.
Old Aug 17, 2008 | 07:35 PM
Thanks alot, I just did it and my engine light is still on, so it is probably something else.
Thanks again!
Old Aug 17, 2008 | 07:57 PM
No once you put it back on the codes need to be cleared. It won't go out by itself. AutoZone should be able to clear it for you.
Old Aug 17, 2008 | 11:03 PM
just got back, everything is working good now thanks for your help
debargha
Feb 24, 2015 10:46 PM
bluemagicbus
May 17, 2011 07:18 AM
edahlgren
Oct 21, 2010 06:24 PM
Ahmed
Mar 28, 2008 04:22 PM
