Check engine light - super turns it off
Old Jul 9, 2008 | 08:02 PM
tr_car_nut's Avatar
Default Check engine light - super turns it off
I have been running on regular unleaded for the last seven months (7000 miles) with no issues until recently when the check engine light turned on. I decided to put super unleaded in the car and after about one-hundred miles the light turned off. I'm currently on a trip and have racked up about 1200 miles but the light did not come on till I filled up halfway through the trip in a different state. Early today I filled up with super unleaded and after about an hour the light went off. Am I stuck running super to keep the CEL off?
Old Jul 9, 2008 | 08:25 PM
Eric J's Avatar
Default RE: Check engine light - super turns it off
It may be coincidence or any number of things, like an O2 sensor on its way out. To know what is causing this, go to a parts store and have the codes checked.
Old Jul 10, 2008 | 09:28 AM
mcguij1's Avatar
is your s40 turbo'd? If so I highly advise you to only use premium unleaded fuel, you need the higher octane levels for your turbo and engine to run efficiently...
Old Jul 11, 2008 | 12:02 PM
tr_car_nut's Avatar
The light is off now so I can't read the codes since they are no longer in the computer. Yes this a turbo 1.9L (aren't they all?) and I've been running regular for about six months in the car with no issues. One of the guys I work with has the same car and also runs regular with no problems. I thought maybe bad plugs but the O2 sensor is a possibilty. Yesterday the "Service" light came on for a few minutes and then turned off.
Iggyomega
Apr 10, 2020 07:23 AM
Stb7
Nov 6, 2013 09:12 AM
nautigirl
Jul 10, 2009 07:01 PM
