Clicking Sound While Driving
Old Feb 28, 2018 | 06:33 PM
sublimeswell2's Avatar
Default Clicking Sound While Driving
Hello,
So I've noticed a faint clicking sound while driving to work. It comes from the front passenger side, and it is quite faint. It sounds as if something were clicking on and off. It will go once, and then after a few seconds, it will click again.
What could this be? Is something incorrectly connected underneath the passenger seat? FYI: I recently had my entire interior taken out to fix a sunroof leak, replace the carpet, paint the bottom with anti-mold paint, disinfect, etc. The interior had to be put back in.
Any ideas?
Old Mar 1, 2018 | 05:01 AM
One more thing I forgot to mention: the car has also had its timing belt, AC belt, and serpentine belts replaced. I just bought it about a month ago.
Could the noise be attributed to any of these? It seems to be coming from under the glove box somewhere. I checked last night.
Old Mar 1, 2018 | 07:03 PM
you didn't note if the clicking changes with engine speed, road speed, turning left/right etc. If its just random, I'd suspect its a relay or similar.
Old Mar 7, 2018 | 12:03 PM
The clicking comes from behind the glove box it seems, and it starts whenever I turn the A/C on. If I turn the A/C off and set it to fan only, it stops. Turning it to recirculate doesn't do anything--the clicking continues.
Old Mar 16, 2018 | 06:26 AM
Hudini's Avatar
That is the direction of the A/C compressor.
Old Mar 26, 2018 | 12:09 AM
BerresTyler's Avatar
ya its your ac pump/ compressor engaging and disengaing
Old Mar 29, 2018 | 07:13 PM
So if that's what it is, what do I do to fix it? What do I tell my local shop to do?
Old Mar 31, 2018 | 09:12 AM
It needs it needs to be adjusted or the shims have worn out I'm not exactly sure but it's out of adjustment is my opinion and the shims need to be replaced
Old Mar 31, 2018 | 10:30 PM
firebirdparts's Avatar
It's necessary that it turn on and off. You don't fix it. It has to turn off to prevent freezing. Total refrigerant load will affect it to some degree, but you cannot and should not stop it entirely.
You may get a lot of people telling you it can be fixed, but it's necessary. It's only March.
Old Apr 6, 2018 | 04:27 AM
Hudini's Avatar
Some are louder than others but yes, it's normal. The time for repair is when the air temperature cycles between hot and cold when you have the AC on. Usually the first time you notice this is on the hottest day of the year. The problem is the gap on the AC compressor clutch is too wide but only barely. Then on the hottest day of the year, when the AC is working hardest, that gap expands just a fraction which causes the clutch to disengage. Now after a minute or two the clutch cools down, the gap narrows, and the AC magically works again. The fix is to remove one of 3 shims on the AC compressor clutch which narrows the gap back to within specs. Normally you start with the thinnest of the 3 shims as each is a different thickness. There are threads with pictures showing how to do it. It takes about 20 minutes and can be done by you.
Old Apr 7, 2018 | 08:46 AM
OK, thank you for all of the input, guys. I just feel like in most cars the A/C doesn't click like that while driving. Is there anything else I should tell my mechanic to look at it when he works on it?
Old Apr 7, 2018 | 04:37 PM
Hudini's Avatar
Check R134a refrigerant levels and be gentle on your wallet?
Chloex124
Jan 29, 2017 09:41 AM
cameo
Sep 27, 2011 09:49 PM
blue02
Sep 3, 2011 10:47 AM
jxi
Feb 15, 2011 10:00 AM
elbert
Apr 12, 2006 10:04 PM
