Computer reset
Old Nov 4, 2008 | 02:16 PM
Access Denied's Avatar
Default Computer reset
Ok, I have a 1997 2.0 Petrol Non-turbo S40. The other night I left the interior light on by mistake and drained the battery. I did my back in trying to push it out of my drive as it's a slight incline so I couldn't bump start it. I then jump started it. That went fine but since then below 1500 rpm the Engine Electrical light comes on and if I let the revs drop off too sharply the engine cuts out. I called my local dealer and they told me that it's nothing but my computer will need resetting. Now I don't have the money at the moment to get the computer reset at the dealer but I've hear that it is possible to reser the computer manually but doing things in sequence with lights and indicators.
Is this true and if so, what do I have to do?
Old Nov 4, 2008 | 04:01 PM
Default RE: Computer reset
Sorry im not sure as I live in the U.S. we only have 2000 and up turbo models. Some can be rest by disconnecting the battery.
Old Nov 4, 2008 | 08:01 PM
hordezla's Avatar
Hey Tech, I can relate to the problem above. 2003 volvo s40, abs and CEL are on. Our obd2 reader can not clear the CEL because there are no codes stored, it reads 0 but light is still on like it has pending codes. How is this possible? I am 100% sure that abs light is on because of the same problem. Battery is brand new. Something needs to be reset or some strange electrical problem occured? ANy ideas?
Old Nov 4, 2008 | 08:22 PM
Your Generic scanner cannot read the codes. Most Generic scanners will not read the S40 and newer cars.
Old Nov 4, 2008 | 08:34 PM
hordezla's Avatar
It already read codes on this car before. What are the chances ofABS and CEL being on for the same reason, something electrical?
Old Nov 4, 2008 | 08:56 PM
Possibly but I doubt it. The scanner will read some of the codes but not all of them.
Old Nov 4, 2008 | 09:09 PM
hordezla's Avatar
ok thanks...
Old Nov 5, 2008 | 04:15 PM
hordezla's Avatar
hey tech, here I am again
We found a mechanic that had software to read the abs codes and he pulled :wheel sensor signal, right rear wheel, fault in the circuit, permanent malfunction. So we ordered new rear sensor and I was wondering after we install it would abs light go off by itself or it needs to be cleared by computer?
thanks!
Old Nov 5, 2008 | 04:26 PM
It will need to be cleared.
Old Nov 5, 2008 | 07:59 PM
hordezla's Avatar
ok, I will take it to the same guy and report back here. thanks!
Old Nov 16, 2008 | 04:28 PM
ekolaendzi's Avatar
Ok, rear abs sensor was replaced and light went off immediately. That is taken care off. CEL is still on and obd reads 0 codes. I cant clear CEL if car is running, I need to shut it off and then clear it. We brought it to autozone just to make sure that our reader is fine and same thing occured. What do you think?
kptvn
May 19, 2016 09:32 PM
trrieger
Mar 6, 2010 10:31 PM
dlbeck
Sep 24, 2008 02:20 PM
wolfman75
Jun 24, 2008 07:56 PM
S70driver
Feb 24, 2008 10:59 PM
