crankshaft sensor
Old Jan 25, 2009 | 05:13 PM
rupert77's Avatar
Default crankshaft sensor
where is the location of the crankshaft position sensor on my s40?
Old Jan 25, 2009 | 05:40 PM
Default RE: crankshaft sensor
It basically mounts to the top of the transmission at the motor.
Old Jan 25, 2009 | 06:42 PM
rupert77's Avatar
thanks. Just to let you know that i have found out that there is no specific fault code associated with the crankshaft sensor it may read fault code 18 19 which is a common code for camshaft sensor and even though thats what came up on my diagnostics test (FAULTY CAMSHAFT SENSOR) it can be the crankshaft sensor and this sensor will stop a car from starting if it is faulty.
Old Jan 25, 2009 | 06:43 PM
Hopefully that is the problem.
Old Jan 26, 2009 | 05:22 PM
rupert77's Avatar
finally i've got it up and running again!! How??
I re-istalled my old fuel pump that the fuel gauge doesent respond to and she fired up without hesitation.
Is there a lesson to be learned here, yes, only use the same part as the part that you are replacing.
The fuel pump that i got for it was out of a 2000 s40 1.8 and mine is a 2002 2.0.
Didn't think that it would'nt run as it worked my fuel gauge, but now realise that it wasn't powerful enough to send the petrol right up to the FPR.
Have to find the cause for the relays shorting now, but hopefully it wont be as big as pain than what i put myself in this time around.
Old Jan 26, 2009 | 06:34 PM
Glad you are getting it licked!!!
joe maroon 850
Apr 2, 2011 02:04 PM
the_brain3000
Aug 4, 2010 02:31 PM
Jomo1994z71
Jan 4, 2009 10:37 AM
Mike K.
Aug 20, 2008 06:02 PM
starkeyd
May 5, 2007 01:07 PM
