Cylinder two misfilre
Old Jul 14, 2014 | 12:11 PM
Newport_j's Avatar
Default Cylinder two misfilre
My check engine light came on and I went to Autozone to have the code read. I have a cylinder number 2 misifire. The tech said it is most likley the sparkplug or the coil above the sparkplug. What is the coil and how would that cause a cylinder misfire?
Any help appreciated.
Thanks in advance.
Respectfully,
Newport_j
Old Jul 15, 2014 | 04:36 AM
pierremcalpine's Avatar
If the sparplugs have not been recently replaced (as per service schedule) I would start by putting four new genuine plugs on there. If they have been replaced then your mech is right in that coil may be defective. Apparently the coils develop hairline cracks that disrupt current flow to the plug. I have heard of some folks finding them and fixing them which you could attempt but prob best to simply purchase new coil(s).
Old Jul 15, 2014 | 08:05 AM
mf70's Avatar
What year is your car? What mileage?
Overview of procedure here:
Later 5cyl is similar.
Old Jul 16, 2014 | 07:52 AM
Newport_j's Avatar
Default car year and mileage
The car is a 2002 Volvo s0 with about 188,000 miles on it. It has been well taken care of.
I hope this info helps.
Resepctfully,
Newport_j
Old Jul 16, 2014 | 10:35 AM
mf70's Avatar
If you have DIY experience, you shouldn't have any trouble with pulling the plugs. You should be able to judge if that vid applies to your car. Make sure the engine is clean before you open it up.
On the preventative side (not related to the misfire), has the trans fluid been changed? Timing belt?
Old Jul 16, 2014 | 12:00 PM
Newport_j's Avatar
Default transmission fluid
I know the timing belt has been changed. I do not kow about the transmission fluid. I can only dip the stick to see how much and how clean it is.
Respectfully,
Newport_j
jbuck
Nov 16, 2011 05:48 PM
Typhoon
Feb 16, 2008 07:15 AM
twofourdee
Nov 28, 2005 09:11 PM
ronski
Nov 27, 2005 08:41 PM
dece207
May 6, 2005 09:00 PM
