dashboard light replace
In my 2002 Volvo s40 the clock light is out. it is beneath the tachometer. Also, the right half of the tachometer and the left half of the speedometer are dark. I must replace these that light also.
What is the part number of each light and how do I put them in?
Thanks in advance.
Newport_j
Thanks in advance.
Newport_j
Don't know the light number. The bulbs are accessed by removing the instrument cluster. This is tight but straightforward. I tilted the steering wheel down full. Removed the 2 phillips screws holding the plastic surrounding the cluster. Now unscrew the small screws holding the cluster. To remove the cluster give it a firm pull to free it from the 2 connectors on the back side. Once free you can gently work it out of the dash. It's tight but it will come out. If the lights are like the other dash lights you will have to get them from the dealer.
emacsp
12-11-2015 02:57 PM
