digital clock light out
Old Aug 3, 2011 | 07:58 AM
Newport_j's Avatar
Default digital clock light out
My 2002 Volvo s40 has a dashboard light prblem. The light on the digital clock is not working. The digital clock works fine, but at night I cannot see it because the light is now out. The clock is located at the bottom of the tachometer on the lower left section of the dasboard.
What light do I replace it with and how do replace it?
Thanks, any help appreciated.
Newport_j
Old Aug 6, 2011 | 12:08 AM
Hudini's Avatar
I can't remember which bulb I used but it was not hard to find. I do remember using a magnifying glass to read the bulb markings because the bulb is quite small.
It's a straight forward process. Tilt the column all the way down. Remove 2 phillips screws on the plastic instrument cluster surround. Pull the surround out from under the glare shield and above the steering column. Remove the screws holding the instrument cluster. Pull the cluster out the same way as the plastic surround. The 2 male electrical connectors plugged into the back of the cluster will come free as you remove the cluster. (easy to understand once you see it)
Now all the bulbs are attached to the back of the cluster so find the one giving you trouble and replace it. Installation is reverse of removal. Just line up the 2 male electrical connectors with the open slots of the cluster and carefully press the cluster in until you hear the connectors click into place.
Old Aug 9, 2011 | 09:23 PM
Newport_j's Avatar
Default Need part number
Okay, so what is the part number of this digital clock light bulb?
Newport_j
Old Apr 23, 2012 | 03:07 PM
klhoush's Avatar
I have the clock bulb out on my 2002 S60. Does anyone have replacement instructions? Sounds pretty easy on the S40.
Kurt
Skyharbor12209
Aug 13, 2015 07:22 PM
porkchop112699
Oct 18, 2012 04:37 PM
bahstunbob
Jul 17, 2008 08:02 PM
daithil
Apr 15, 2007 06:48 PM
s_vanvooren
Oct 19, 2005 02:17 AM
