Driver side whistling, howling 2005 S40
Old Jan 3, 2016 | 04:12 PM
ballen017's Avatar
Default Driver side whistling, howling 2005 S40
Today I test drove a 2005 S40, 2.4i with 92k miles. During the short test drive I noticed a whistling or howling noise that seemed to be coming from behind or under the dash area. The sound was similar to when you blow across the top of a bottle. During the test drive the sound seemed to oscillate in volume.
When at a red light for a while it stopped, then started again when I started driving again. Once back at the lot it seemed to continue with constant volume at idle. I could not hear the noise outside the car or under the hood, just inside.
The noise was present with the a/c & fan on or off. I moved the vent deflectors around and that was not it.
I really like the car but did not buy it yet. I did some research here and it seems this may be the brake booster? If I go back is there any test to verify this, or any other likely thing to check for?
This would be my first Volvo. Thanks.
Old Jan 6, 2016 | 10:16 PM
Considering you are looking at buying the car (vs repairing your own), the prudent thing to do would be to tell the owner to have a mechanic assess the problem. There's a few things that can create noises like this - vacuum pump, brake booster and some odd things in the power steering etc. Unless you can find the source while the car is parked (you can try using a hose as a listening tube), best to have a pro assess the issue (so you can factor the repair into your offer) or pass on the car.
apple4life
Jul 24, 2010 06:01 PM
sVolvo60
Jul 21, 2010 12:56 AM
armeca
Apr 6, 2010 07:12 PM
jsxxx
May 14, 2009 05:26 PM
8T9GTA
Nov 24, 2007 09:22 PM
