EGR Valve Removal, 2001, S40, 1.9TD, Engine Number D4192T3
Old Oct 1, 2007 | 08:43 AM
paul9038's Avatar
Default EGR Valve Removal, 2001, S40, 1.9TD, Engine Number D4192T3
Can anyone help with how I remove the EGR valve. Apparently it needs either cleaning or changing as it can affect engine economy, performance and can cause the car to stall. 3 bolts hold it onto what I think is the exhaust manifold but even when I remove them I cannot remove the valve. Does anyone have any ideas or suggestions as to the possibility of the valve being responsible for stall problems that I'm still having and whether it can be cleaned when removed or does it need a straight replacement. Is there a special tool to remove it? I haven't been too forceful when trying to remove it for fear of unnecessary damage being cause.
Any ideas greatly appreciated
Old May 29, 2008 | 08:05 AM
Kawakers's Avatar
Default RE: EGR Valve Removal, 2001, S40, 1.9TD, Engine Number D4192T3
ORIGINAL: paul9038
I am having the same problem as above so any hints and tips greatfully recieved,
thanks Andy
Old May 29, 2008 | 01:54 PM
billofdurham's Avatar
VADIS instructions are: Ignition off. Clean the surfaces around the valve. Remove the connector for the EGR. Remove thethree screws and remove the valve. As you have done this I would suggest you get a little more physical with it.
There is no special tool except No.1 brute force.
It may be responsible for the stalling problem. I don't think it is possible to clean the valve.
Before replacing the valve make sure the mating surfaces are clean.
Old May 30, 2008 | 11:22 AM
Kawakers's Avatar
Bill, Once again thankyou very much
VTBricked
Dec 30, 2009 09:11 PM
Kawakers
May 29, 2008 01:57 PM
paul9038
Aug 16, 2007 09:00 AM
glover1968
Mar 11, 2007 03:12 PM
rousha
Jul 19, 2005 05:18 PM
