Engine Compartment Fuses
Old Dec 10, 2008 | 12:16 PM
forregim1's Avatar
Default Engine Compartment Fuses
Greetings,
I own a 2000 S40. Recently, the power to the remote keyless entry, glove compartment, trunk, etc. went out. I looked in my owners manual and found that I needed to replace fuse #5 in the engine compartment fuse box. I could not remove the fuse because there is a yellow encasing around fuse #5,#6, and #7. Can I remove this casing or do I have to bring it back to the dealer?
Thanks in advance.
Old Dec 10, 2008 | 01:25 PM
forregim1's Avatar
Default RE: Engine Compartment Fuses
Problem solved. Apparently the box doesn't come completely off. I couldn't pull it up with my fingers and used a screwdriver as a lever to edge the yellow box upward. When I performed this action, I was able to remove the fuse. Thanks.
Old Jun 12, 2009 | 04:49 PM
Tim_Dallas's Avatar
Reggie,
I also have a 2000 S40 and ran into the same problem. Can you tell me a little more on how you removed the yellow casing? I used a small screw drive on both sides to pull out the yellow case that holds the 3 fuses but it is not really pulling.
I was also told that I need to get the radio code known as it gets erased when the yellow casing is pulled out. How did you get that done?
Would appreciate your help.
Thanks.
-Tim
phillym
Dec 14, 2008 07:06 AM
NetAvatar
Feb 28, 2008 05:43 PM
Capo Cam
Feb 23, 2008 10:19 PM
rob180
Jul 5, 2007 05:20 PM
VW
Nov 30, 2006 05:11 PM
