Engine Warning light suddenly on
Old May 19, 2006 | 02:58 PM
spyda's Avatar
Default Engine Warning light suddenly on
Hi,
I have been driving my 99-2000 S40 2.0 T SE daily for the last few months and have had no problems whatsoever. It has recently been serviced and successfully passed its MOT.
However, today after around 45 mins of driving, I stopped at the bank, got back in the car, started it up and the engine warning light was on.
There has been no noticable loss in performance (perhaps a little less economical but I put that down to rising petrol prices) and the car seems to be driving as well as it ever has.
Is there a simple explanation for this? I have read about the pressure build up that's resolved by loosening the petrol cap and am hoping against hope that this is the problem, but why now after several months?
Any thoughts appreciated.
Thanks.
Old May 19, 2006 | 08:28 PM
Default RE: Engine Warning light suddenly on
It could be many things you need to have the Codes pulled first to see what the computer says it is.
Old May 20, 2006 | 08:29 AM
spyda's Avatar
Thanks for the response ... I figured that might be the case.
However, I have managed to get rid of the light. I went for a drive round the block, turned off the engine while driving, engaged 3rd and bump started the car. Since then, no light!
I am guessing it was related to the petrol cap / pressure readings.
Will see how it goes...
Old May 20, 2006 | 10:54 AM
subzero092802's Avatar
I have a 2000 s40 and hve only put about 150 miles on it since purchase. Ilet my wife drive it to work and now my lite is on too. I am taking it to a dealer today if it does not clear itself out.
Old May 24, 2006 | 01:30 AM
Ihatespeedbumps's Avatar
As tech said you need to take it to volvo and have the codes read. It could be something very simple or something a bit more complicated. Your volvo dealer will be happy to print out a list of the trouble codes on your car.
Old May 26, 2006 | 06:20 PM
I went to Volvo today. Same thing P0128 i think it was. I go in tuesday to replace sensor and flush coolant...Volvo has told me that it is not a drivability issue...
Old May 29, 2006 | 02:46 PM
now all of a sudden,my temp gauge goes haywire, up down,up down, and then my car decides that it wants to overrev....it runs a constant 2000+ rpm's, and if i let it go will do 60+mph on it's own. help. it goes into the shop tuesday
Old May 29, 2006 | 05:59 PM
Signs of the Bad coolant temp sensor.
Old May 30, 2006 | 01:33 AM
jojoswhip's Avatar
where can we get a good temp sensor? does it have to be a dealer part? my next question is what kinds of things happen when the p0128 code comesup. will the car run rough at all?
Old May 30, 2006 | 10:55 PM
Cooling Fan might run all the time,Idle might Rev high,Cooling fan might not work,A/C might not work.
Not sure where else to get but at the Dealer.
Old May 31, 2006 | 11:12 AM
got my baby fixed yesterday. everything is good. Volvo said it is not a drivability issue, don't beleive it, all the problems i was having in my earlier post were of direct relation to that sensor. get it fixed as soon as possible, dealer prices run above 200$ for replacement and parts
Ken R
Apr 14, 2011 03:09 PM
Zoltan64
Apr 13, 2011 04:40 AM
bnemser
Feb 16, 2009 11:12 PM
zoomy
Jun 12, 2006 01:59 AM
kem041175
Sep 9, 2005 10:36 PM
