Suddenly no sunroof
Old Apr 23, 2006 | 02:35 AM
zoomy's Avatar
Default Suddenly no sunroof
Hi,
I have a nice 1993 940 turbo, and yesterday I wanted the sunroof open. I hit the switch, nothing happened. The roof has always worked in the past, but I did notice that the switch hesitated the last couple of times, I had to hit the button a couple of times before it worked.
Do I need a new switch? The fuse is intact, that is if fuse #10 is the right fuse.
Thanks,
Tim.
Old Apr 23, 2006 | 02:59 AM
Default RE: Suddenly no sunroof
I will bet it is a bad switch.
Old Jun 10, 2006 | 05:07 AM
zoomy's Avatar
I changed the switch with a new one, but it hasn't solved the problem. I also tried to open the roof manually, but the crank won't turn, it appears to be locked in place. Any suggestions?
Old Jun 10, 2006 | 09:51 AM
Something might have gotten jammed.
How exactly did you try to open it manually?
Old Jun 10, 2006 | 02:16 PM
zoomy's Avatar
ORIGINAL: tech
I removed the panel on the ceiling, and there is what appears to be a crank shaft with two notches. I tried turing it with a pair of needlenose pliers, but there was no movement.
Old Jun 10, 2006 | 09:05 PM
You might be able to stick a screwdriver in there and get it to turn.
There should be a little pin type thing in the center. That has to be pushed in then it might turn for you.
BUT BE VERY CAREFUL TRYING TO TURN IT.
Old Jun 11, 2006 | 07:26 PM
cbevis's Avatar
Did you check the fuse?
Old Jun 12, 2006 | 01:59 AM
crazynlazycolombian's Avatar
similar happened to me but it ended up me $940 in the hole.....the track "teeth" were worn and had to get that all replaced
word to the wise....dont go the volvo dealer for this repair....labor to overpriced for this job atleast.....
if you have a local headliner/sunroof specialist or maybe even a good body guy that you trust
Ken R
Apr 14, 2011 03:09 PM
mbwittig
May 8, 2007 03:51 PM
jonnycd
Dec 26, 2006 09:39 AM
spyda
May 31, 2006 11:12 AM
kem041175
Sep 9, 2005 10:36 PM
