Evap problem code p0456
Old Nov 20, 2006 | 11:50 PM
skatermattc2's Avatar
Default Evap problem code p0456
I have a 2001 volvo s40 and have been getting the p0130 (02 sensor circut malfunction "bank 1 sensor 1" ) code for two weeks. The check engine light came on about three times with this code. Now today the check engine light came on again and the code is p0456 (evap emission control system leake very small). Any corelation between theses two codes? Thanks for the help.
Old Nov 24, 2006 | 10:36 AM
Default RE: Evap problem code p0456
They are 2 different systems.
Old Nov 26, 2006 | 08:55 PM
Any ideas on what could be causing the evap code?
Old Nov 27, 2006 | 08:07 PM
Could be a bad Evap valve,evap canister,Bad hose.
Do you have access to a Compressor,Vaccum,pressure guage,Pressure regulator?
Old Nov 27, 2006 | 08:29 PM
yes.
Old Nov 27, 2006 | 09:12 PM
Follow process in the following post to look for the leak.
https://volvoforums.com/m_45619/tm.htm
Old Nov 28, 2006 | 11:58 PM
thanks I will try this.
Old Dec 12, 2006 | 02:15 PM
Well No evap code lately. A friend told me that topping off my gas tank will set that code off. So hopefully I fixed things. If I keep getting the code I will try the vaccume procedure. Thanks for the help.
Old Jan 10, 2020 | 10:01 PM
Aeatkins73's Avatar
I realize this is a REALLY old post however when I click the link in you’re post it says it doesn’t exist anymore. Could you possibly repost it? Thx
crashin
Feb 26, 2011 07:10 PM
KeithB
Dec 2, 2010 12:57 PM
Byroni616
Apr 14, 2008 08:10 PM
jmd
Mar 28, 2008 10:51 AM
nbac3k
Nov 20, 2007 06:46 PM
