Error code - Gas Leak Evap
Old Sep 14, 2007 | 08:34 AM
nbac3k's Avatar
Default Error code - Gas Leak Evap
I have a 98 S70. It has 135,000 km on it, and for the last couple years (since 2002) the engine light has been on. I've had almost everything checked out. My mechanic resets the light then within 24 hours the engine light comes back on. any help on this would be greatly appreciated!!!
Old Sep 14, 2007 | 08:57 AM
JPN's Avatar
JPN
Default RE: Error code - Gas Leak Evap
Bon Jour,
Greetings from Narita, Japan.
Check the gas cap, especially the rubber O-ring for its integrity.
If the gas cap turns out fine, then see attachment. There is only one device within the Evaporative Emissions system that has electrical connector, and the problem could be either the valve is faulty, or something else is faulty and telling the valve to trigger CEL. (Based on the 850, but the S70 would be similar, correct me S70 drivers if I'm wrong).
I hope you find it helpful,
JPN
Old Sep 15, 2007 | 08:17 AM
There is a Vent hose on the top of the tank that is starting to crack on these cars.
They are at about the age now where we are starting to see alot of them.
I made a special tool at work to pressurize the system and monitor for leaks.
Thats what you need to have done.
Old Sep 21, 2007 | 09:38 AM
akbar's Avatar
JPN > My 98 S70 has five components for the EVAP system.
1. Canister purge valve. Mounted near the radiator.
2. EVAP canister mounted near right rear wheel.
3. EVAP canister shutoff valve. Mounted above the canister.
4. Fuel tank pressure sensor mounted on the fuel tank.
5. EVAP canister shutoff valve air cleaner. Mounted to the fuel tank filler tube in right rear fender.
NBAC3K> If you'll do a search for "p0172" there are some posts that will give you some ideas on what to look for and how to check for the air leaks that Tech mentioned. But it will take a few tools that the average guy might not have. ie' air compressor and regulator, also a vaccum pump.
Long story short my problem turned out to be the canister purge valve.
Old Sep 21, 2007 | 11:49 AM
JPN's Avatar
JPN
ORIGINAL: akbar
Thanks, I just edited my previous post. I wanted to say devices that have electrical connection, and in the case of 850, there is only one EVAP device that has electrical connection that could trigger CEL and store codes. I wonder how much differences there are between the S70 engine & 850 engine.
JPN.
Old Nov 20, 2007 | 03:19 PM
volvovolvo's Avatar
Hi, I have the same issue as noted above. Check engine code PO442 and PO445. I replaced the gas cap to no avail. Wondering how to check the EVAP valve solenoid( and it's location) and the best way to check the vent hose on the tank(does it require dropping the tank?). I also have been getting gas smells in the cabin from time to time too. What could be leaking and where in order for the smell to come inside? I recently did the timing belt and water pump too.
Help is greatly appreciated!
1998 S70 GLT with 208,000 miles
Old Nov 20, 2007 | 06:46 PM
You can access the pump and top of the tank from inside the trunk.
Take the carpet mat out and you will seea metal cover remove it and look inside.
Rrvarnum
Feb 8, 2015 12:59 PM
breachandclear
Feb 28, 2011 12:27 AM
htowncourier
Jul 7, 2008 10:33 AM
Eric J
Jun 21, 2008 06:13 PM
sdeering
May 22, 2007 12:55 AM
