faulty gauge or leak in lines??
Old Jun 13, 2008 | 07:35 AM
chimmychong's Avatar
Default faulty gauge or leak in lines??
I installed my boost gauge and it sucks.....
I found a crack in a line but its so close a T that I dont think it is a problem.... clamped down all the ends of all the vac lines ... and my boost gauge readings suck ***........
whats the vac pressure supposed to be for a stock s40.... and what boost would it read.....
my boost doesnt even go over 0 when I gun it
heres what it reads when i just start up the car... its kinda different every time and the needle wants to go past 30 some times... some times it stays at 25 and some times it flutters
thats what it reads when the car is off now.... used to be at the 0...lol
cheap *** gauge from japan ebay
Old Jun 13, 2008 | 09:32 AM
mcguij1's Avatar
Default RE: faulty gauge or leak in lines??
Could either be the gauge itself, but seems like you have a leak...your psi when your flooring it should reach if stock around 8-10 psi...Im not sure with the whole vacuum thing as my gauge starts at 0 psi and only goes up from there...
Old Jun 13, 2008 | 01:50 PM
wouldleaks in my vac lines cause any performence issuses??
Old Jun 13, 2008 | 01:56 PM
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/KoOye9u6h4k&hl=en"></param><embed src="http://www.youtube.com/v/KoOye9u6h4k&hl=en" type="application/x-shockwave-flash" width="425" height="344"></embed></object>
the needle is supposed to go down and show a vac reading and then go up when presssing the gas to show you the boost your using
Old Jun 13, 2008 | 02:11 PM
also where are you guys teeing off from or does it even matter?
jw144
Nov 15, 2013 08:48 AM
jnduke
Oct 29, 2009 10:00 PM
PHIL_V70_GLT
Feb 22, 2009 09:49 PM
krisby
Mar 20, 2006 11:53 PM
