FPR question?
Old Jan 24, 2009 | 05:31 PM
rupert77's Avatar
Default FPR question?
If you take the FPR out should you be able to suck air through it from the vacum shaft?
Old Jan 25, 2009 | 08:39 AM
Default RE: FPR question?
No you shouldn't. It should pull vacuum and hold.
When you say take it out though do you mean the entire thing from the fuel rail or only the metal section?
Old Jan 25, 2009 | 03:27 PM
rupert77's Avatar
Just the webber metal cylinder with the vacum shaft and the syves! So you think this isnt my problem why my car wont start?
Old Jan 25, 2009 | 05:18 PM
If the metal part is out and the plastic housing is still on then you will be able to blow air though because the diaphram is not in there.
Did you check it like I have explained many times on the site?
After the car sits for a while pull the hose off where it attaches to the intake. If there is gas in there it is bad. And if you can smell gas in the hose it is bad.
volvoguy23
Mar 24, 2012 09:39 AM
laxman1100
Apr 28, 2011 11:15 AM
mountaineer
Feb 4, 2009 04:56 PM
Forsyth
Sep 1, 2008 01:31 PM
bkraff18
Jun 24, 2008 08:45 AM
