Front end wobble
Old Aug 20, 2011 | 10:39 AM
DustyPlains's Avatar
Default Front end wobble
I have a 2000 s40. The stearing wheel twitches to the right at very slow speed and developes into a vibration and thumping at high speed. Wife swears she has not hit a curb. Wear seems fine on tires. There is brake noise and a loud humming from the rear at high spead all of which goes away when braking or slightly swerve left. Pads look fairly new but front rotors could use replacing.
Old Aug 22, 2011 | 06:18 PM
fcpgroton's Avatar
Former Sponsor
Welcome to the forum.
How many miles are on the car? It could be an issue with a worn ball joint or an axle.
Old Aug 23, 2011 | 06:34 AM
Default Solution found
Despite checking the tires several times previously and finding no problems, it was the left front tire. I jacked the front end up, ran the car in gear to see if a rim was bent and found that the left front tire was bulging. Belts had separated.
Old Aug 23, 2011 | 06:10 PM
fcpgroton's Avatar
Former Sponsor
Nice find. The only other way you would have found that would have been to have them road balanced. Glad that she is all fixed now.
garysvolvo
Jul 2, 2014 02:58 PM
Kiwi84
Dec 2, 2012 02:17 PM
dejr
Nov 23, 2012 10:47 AM
RickB
Feb 1, 2010 12:29 PM
WagHag
Jan 2, 2007 09:09 PM
