Front wheel brake splash guards
Old Sep 8, 2015 | 03:17 PM
Newport_j's Avatar
Default Front wheel brake splash guards
I have had to look into replacing the brake plates (splash guards) on both of my rear wheels of my 2002 Volvo s40. I need to know if these are only on the rear wheels or are they on the front wheels also?
If they are on the front wheels what are the parts numbers?
Any help appreciated.
Thanks in advance.
Respectfully,
Newport_j
Old Sep 8, 2015 | 05:49 PM
Gen 1 S40 front splash shields are PN 30818029 and 30818030
Old Jun 27, 2016 | 11:48 AM
Newport_j's Avatar
What are the part numbers for the rear splash guards, and can they (both rear and front splash) be installed during a routine tire rotation? After all the tires are coming off anyway to be rotated.
Respectfully,
Newport_j
Old Jun 27, 2016 | 12:21 PM
access to the splash guards requires caliper and disk removal so you will need to remove the wheels but its a much bigger job than just rotating tires.
2002 Volvo S40 2.0l 4 cylinder Turbo. #30814870: Backing plate, left
Old Feb 28, 2017 | 08:00 AM
Newport_j's Avatar
Default Is it time to replace the spalsh guardrs now?
Okay at this point in time, I must replace the whole brake assembly, brake pads and brake rotors on each wheel. I must even replace the stabilizer links. My question is during this major brake overhaul and replacement is it a good to replace the tire splash guards? After all I will be disassembling all four wheels on the 2002 Volvo s40.
It seems that now this repair is much more elaborate that simple tire rotation. So is it time to replace splash guards now?
Any help appreciated. Thanks in advance.
Respectfully,
Newport_j
Old Feb 28, 2017 | 09:57 PM
AutoNaut's Avatar
If you have it down that far, the splash shields would be easy.
Old Mar 3, 2017 | 12:03 PM
Newport_j's Avatar
Okay, I will buy them. I know that I need to replace them.
Can I get the lower cost Mitsubishi splash guards that fit the 2002 Volvo s40? If so what are their part numbers? I want guards for all four wheels.
Respectfully,
Newport_j
mt.girl
Mar 4, 2010 09:36 PM
PhotoDu.de
Sep 22, 2009 03:46 PM
TexasXC90
Aug 30, 2009 12:41 PM
Rickc10ny
Oct 21, 2007 06:26 PM
