Fuel Filter
Old Jul 2, 2008 | 01:37 PM
Andrew.Gillespie1's Avatar
Default Fuel Filter
I want to change my fuel filter. Do I have to use a Volvo fuel filter? Or are there some generic brands that are good? I really don't want to wait for one to come in the mail.
Old Jul 2, 2008 | 01:50 PM
Eric J's Avatar
Default RE: Fuel Filter
Welcome to the forum Andrew.
You can use good aftermarket ones. Make sure it looks and measures the same at the connections.
Old Jul 2, 2008 | 10:42 PM
mncx's Avatar
cut the strap off original filter and cable tie back onto bracket...
Old Jul 3, 2008 | 09:45 AM
mcguij1's Avatar
I highly recommend you go to s40concepts.net, go to their "how-to" section and it gives you specific instructions on changing the filter...
Old Jul 5, 2008 | 01:40 PM
Default all kinds of jacked up
I bought a new filter from Volvo. I put the car on a lift, and couldn't find the filter! We traced the fuel line all the way from the fuel tank to the engine and did not see it. I don't think it is inside the fuel tank either.
Also, the instructions at s40concepts.net talked about disconnecting the fuel pump fuse then starting the car until it dies to relive pressure. But, there is not a fuse for the fuel pump in the fuse box.
Old Jul 15, 2008 | 03:12 PM
Default RE: all kinds of jacked up
Most of the plastic under the you can see past with a little bending and getting up close. But on s40concepts.net they were saying you had to remove some plastic to get to it. Shouldn't you be able to spot the fuel filter without removing every bit of plastic on the underbody?
Old Jul 15, 2008 | 07:02 PM
mcguij1's Avatar
the fuel filter is found behind the rear driver side seat....
timoc663
Aug 14, 2016 05:35 PM
inilegna
Sep 25, 2013 03:27 PM
smithnr
Apr 8, 2013 04:56 PM
CoVoVo
Oct 24, 2012 10:19 PM
AnEskimo
May 15, 2011 12:32 AM
