Fuel filter not filling
Old Jan 5, 2018 | 12:55 PM
Seans's Avatar
Default Fuel filter not filling
I have a 2006 Volvo S40 1.6d I've been having problems with air getting in through the injectors so was hard to start first thing in the morning but today it wouldn't start at at not fuel getting to the engine so I took the filter out and it was bone dry I have been told it could be injectors or high pressure pump
Old Jan 5, 2018 | 01:18 PM
GerBeGurGya's Avatar
Do you live in cold weather?Your fuel line could be frozen.
Old Jan 5, 2018 | 01:27 PM
Seans's Avatar
Coldest we would get is probably-5
Old Jan 5, 2018 | 02:55 PM
C or F?Either way water freezes at below 0C so you have a pretty good chance to have this issue.Try some fuel antifreeze additive that should take care of the water in the fuel.Even if this will turn not to be the problem it will not hurt.
Old Jan 5, 2018 | 04:01 PM
Seans's Avatar
My egr valve is supposably sticking would that cause a problem with the fuel filter filling
Old Jan 5, 2018 | 05:26 PM
I don't see how.
Old Jan 22, 2018 | 10:37 AM
Seans's Avatar
Has anyone ever have a problem with a turbo in a 1.6 diesel S40 I've been told I need to replace my engine because the turbo has gone is this true or will I get away with changing filters and oil
Old Jan 28, 2018 | 08:11 PM
Hudini's Avatar
I would check on the UK forum first. Many people with diesels there. Most people (if not all) here are from North America and drive the gasoline version.
paulkite
Aug 3, 2019 10:40 PM
barinthus
Nov 3, 2011 03:57 PM
612diablo
Apr 10, 2010 09:21 PM
dhynes
Jul 4, 2009 01:05 PM
isons2004
Sep 27, 2005 09:30 PM
