Fuel pressure regulator
Old Nov 17, 2010 | 10:45 AM
  #21
barwick11's Avatar
On that note, is there something special about this regulator that makes it cost over $200? I don't see any wiring that goes to it in the picture (haven't looked on my car to verify this).
If I were to buy an aftermarket FPR, is the rate of fuel pressure rise so very different on these cars that an aftermarket one wouldn't work? I've just got problems spending over $200 on something so simple as a freaking FPR...
Old Jun 2, 2011 | 06:01 PM
  #22
volvolini's Avatar
I am pretty sure you can buy just the insert (not the whole plastic piece) and replace just that. That would be much cheaper, about $100 maybe. But you would have to look for 2003 or 2004 s/v40 regulator i think because 2000-2002 only comes with housing.
Old Jun 8, 2013 | 03:22 PM
  #23
mg0698's Avatar
Hey guys I have a 2000 Volvo s40 it takes a while to start maybe 7 seconds when it has been sitting there, But if I just started it and came back 10 mins later it would start right up.
I changed the fuel filter, air filter spark plugs. Problem remains. I took it to the auto shop they tested the battery and said it was fine, But said the alternator is on it's way out.
But I have been reading on here it may be the fuel regulator. So What do you guys think?
Once it starts it drives perfectly.
Old Jun 11, 2013 | 05:03 PM
  #24
mjcahill2009's Avatar
Sounds like the same problem as my 00 S40. Does yours jump while idling sometimes? I'll be replacing the FPR tomorrow on the condition that my local junkyard has one in stock. I'll report back.
Old Jun 11, 2013 | 05:24 PM
  #25
mg0698's Avatar
So I bought the part today and replaced it, I bought it at advance auto parts for $113. It took me about 10 minutes to replace.
My first crank wasn't a good sign, It didn't crank right away. I'll give it a few more days and I'll keep updating.
Old Jun 11, 2013 | 05:26 PM
  #26
mg0698's Avatar
Very rarely does it jump while idling once in a blue moon.
Old Jul 8, 2013 | 06:20 AM
  #27
cbarry's Avatar
Post ColinB
I have a 1987 740, and need a fuel pressure regulator. Which other models have compatible regulators?
Old Jul 8, 2013 | 07:17 AM
  #28
Hudini's Avatar
I show it's only $67 at the local Advance Auto. Way cheaper than any S40 FPR.
Old Mar 3, 2016 | 01:38 AM
  #29
S40_Casey's Avatar
Can someone post a link to purchase that S-Shaped Vacuum hose here in the USA? The part I bought did not come with it (although it showed it online connected to the FPR when I bought it), and seems silly to me not to replace that part after spending $125 for the new FPR. Cannot find it anywhere.
Link to part: BWD 24114 - Fuel Pressure Regulator | O'Reilly Auto Parts
Old Sep 11, 2017 | 08:17 PM
  #30
pmondrian67's Avatar
Default What is the hose next to the Fuel Pressure Regulator?
I was checking out my fuel pressure regulator (which I think needs to be replaced). I found that the long black hose (which is vertical and to the immediate right of the FPR in the Hudini's picture) isn't solidly connected to anything. It slips into a hole right below the FPR but one can pull it easily. What is this hose and is it supposed to be solidly connected? I can't find it identified anywhere. Thanks in advance.
Followup: As long as someone knowledgeable is responding, can you also tell me what the hose is that is to left of FPR in the picture (it's hard to see).
Originally Posted by Hudini
Stole this from Andy. The red circle is where the fuel line connects to the fuel pressure regulator. The FPR is the black plastic piece that is held to the end of the fuel rail by one bolt. The rubber elbow connects to the vacuum source and is just out of the picture below the FPR. As said above, this is covered with a black plastic piece.
Attachment 24149
Last edited by pmondrian67; Sep 11, 2017 at 08:19 PM. Reason: additional question.
Old Sep 13, 2017 | 12:32 PM
  #31
TEEKAY's Avatar
The little hose directly to the left and below is the elbow piece.
https://www.ipdusa.com/products/1036...nedcar-s40-v40
Slips over on both ends. If that's not the hose you are referring to please snap a pic pointing at it.
Old Sep 14, 2017 | 04:45 PM
  #32
Thanks, but that's not the one. I took two pictures, showing the hose in and out (there's nothing holding it in except for gravity -- the car runs fine once it starts). This is just to the right of the fuel pressure regulator, that you can see on the left.
mystery hose next to FPR
hose removed. should there be a connector securing it? I can just pull it out.
Old Sep 14, 2017 | 06:39 PM
  #33
TEEKAY's Avatar
I want to say it's that ring still in there. I'll take a look at mine.
Old Sep 14, 2017 | 10:30 PM
  #34
Default Hose
Thank you.
1. Should the ring still in there be connected securely to the hose?
2. What is the hose (where does it run to)? I'm sure it's simple but I can't figure it out.
Old Sep 15, 2017 | 05:00 AM
  #35
pierremcalpine's Avatar
That is the infamous brake vacuum hose. I say infamous because it has a check valve at the other end and when the check valve fails you get crappy breaking for the first minute or two when driving in cold weather. It should snap back into place with a plastic ring that is either green or red.
Old Sep 15, 2017 | 05:01 AM
  #36
It runs to the vacuum pump near the master cylinder.
Old Sep 17, 2017 | 11:20 AM
  #37
thank you both!
Separately, I'm now waiting for a multispline screw extractor to arrive in the mail. Whomever installed the old FPR appears to have stripped the screw. It appears to be a hex screw, but none of my hex bits fit into it (not a 4mm, 4.5 mm, or 5mm. Even the standard sizes don't fit). Someone posted that it should be a T20 or T25 but that's not what I have on my 2001 S40.
Old Sep 17, 2017 | 07:54 PM
  #38
You could also try taking your idle control valve out and cleaning it with brake cleaner to see if that makes a difference. That solved my long crank issues. Cheap, easy, low risk.
MntnDewMan
Apr 3, 2024 04:05 PM
slsnumber1
Mar 15, 2011 02:55 PM
Buck
Dec 28, 2005 01:28 AM
cdunning
Dec 28, 2005 01:27 AM
cdunning
Dec 27, 2005 02:58 AM
