Fuel pressure regulator hose
Old Mar 26, 2008 | 06:17 AM
zerochills's Avatar
Default Fuel pressure regulator hose
I have an 03' S40 1.9T, can anybody describe to me where to find the Fuel pressure regulator hose.
Thanks
Old Mar 26, 2008 | 06:58 PM
Default RE: Fuel pressure regulator hose
Remove the throttle cover then look on the end of the fuel rail for the hose coming off of it.
Old Apr 2, 2008 | 09:07 AM
Hudini's Avatar
Are you talking about the vacuum hose for the FPR? It's below and behind the FPR. Goes from the FPR down to the throttle body with two rubber boots and a small short white plastic hard line between. This picture shows where the fuel line connects to the FPR. You can just barely see the vacuum line at the bottom.
Old Aug 4, 2009 | 01:20 AM
shogunkicker's Avatar
how much is that hose and where can i buy one in or around LA???
Old Aug 4, 2009 | 09:39 AM
zerochills's Avatar
Default vacuum line
would that be the vacuum line I would use to apply seafoam? i used to use a vacuum line coming off of the head on my Land Rover.
Old Aug 19, 2009 | 01:31 PM
zerochills's Avatar
Anyone?
MntnDewMan
Apr 3, 2024 04:05 PM
slsnumber1
Mar 15, 2011 02:55 PM
rationull
Oct 30, 2006 03:40 PM
cdunning
Dec 28, 2005 01:27 AM
