Going crazy
Old Sep 1, 2021 | 12:06 AM
Tony N95's Avatar
Default Going crazy
Hi, s40 2008 2.4i owner, I've been dealing over the past 3 years with a rattling noise coming from the passenger side, my dust shield has a crack but I don't know if that could be the reason or maybe the caliper is loose. Has anyone ever bought generic caliper pins?
Old Sep 1, 2021 | 12:00 PM
can you feel any looseness in the caliper or checked the guide pins? how loose is the dust shield? did you also check things like the turbo/exhaust heat shields? personally I wouldn't worry about generic vs Volvo for the pins, I think the question is whether they are worn or installed correctly. Even a $6 Autozone part would fix that issue. You may want to shop around for replacing the shield - part # 30778890 - Tasca shows for $41...
Old Sep 1, 2021 | 12:18 PM
Tony N95's Avatar
I've checked the caliper and It's not loose at all, the guide pins looked fine also but I'll change them anyways. Thanks for the heads up, 41 bucks for the shield seems like a great deal! I'll keep you updated once I replace those pieces and hopefully resolve my problem
michael9898
Nov 27, 2016 01:01 PM
MrNerdist
Jun 4, 2013 04:22 AM
Costy
Mar 10, 2012 08:56 PM
soukio
Nov 4, 2010 11:38 PM
justy75
Feb 16, 2010 11:59 AM
