Hard Brake Peddle until car has warmed up.
Old Dec 10, 2017 | 02:57 PM
diggerdude's Avatar
Default Hard Brake Peddle until car has warmed up.
My 2002 s40 has a hard brake peddle until I drive it for a few minutes and use the brakes a few times. I have another s40 i swapped out the (Brake Booster Vacuum Hose (w/ Check Valve) also the Vacuum Pump. It got a little better but I want my Son to start driving it. But need to sort out the hard peddle.
Anyone have any wisdom on this one? Thanks!!
Old Dec 10, 2017 | 03:20 PM
do you hear the vacuum pump cycle on when you start up cold?
Old Dec 10, 2017 | 03:28 PM
diggerdude's Avatar
Yes, it runs for about 4 to 5 seconds. I also hear it turn on every time I push and let off the peddle. I can shut off the car and 1 hour later pull off Vacuum check valve from booster and it hold a vacuum. I ran out of ideas, fairly new to Volvo.
Old Dec 10, 2017 | 03:48 PM
nothing special about Volvos vs other cars here... just a 15 year old car. The typical issues can be the vacuum lines to the booster, a leaky booster (any hissing when you press the brakes?), sticky calipers or a sticky valve in the ABS (I had to replace the ABS on my 00 S40 when a valve stuck not sending fluid to one wheel/locking the other).
Old Dec 11, 2017 | 07:50 AM
diggerdude's Avatar
I do not hear a hissing, I tried calipers, pump, and check valve with the vacuum lines from another car I have. Not much better, when I test drive it i can tell both front calipers have the same heat coming from them, also the back are the same temperature. I have to start the car and let it warm up and pump the brakes kinda hard a few times and they seem to be OK. I'm just trying to get it right for my 16 year old son to drive.
akpasta
Nov 15, 2013 12:18 PM
marsilver
Mar 13, 2011 08:19 PM
mpower989
May 19, 2009 07:19 PM
CobraO
Jun 14, 2008 09:29 PM
Kimmen
Mar 16, 2008 01:07 PM
