Headlight problem
There is a known problem with the CEM causing the low beams to malfunction. I believe there is a thread somewhere with details on how to open the CEM and replace the faulty bits. Here is one such thread though it's lacking in specifics:
https://volvoforums.com/forum/volvo-...w-beams-68391/
Each low beam headlight has its own relay. When mine failed, I had to remove the CEM and split the case to access the circuit board. Volvo hid the screw under the ID decal. The relays are only $1.72 each, and can be ordered online at www.digikey.com Part number is 255-1240-ND Scroll to select JSM1-12V-5 There will be three identical relays---the two on the left are low beams, and the other is high beam. They need to be carefully desoldered, removed, and replaced. It was not easy, but I did it. Confidence builder, for sure!
