Headlight... Strange problem.
Old Jul 14, 2012 | 07:08 PM
LarryNH914's Avatar
Default Headlight... Strange problem.
Hi,
My low beam went out, so I replaced the bulb. No go. It was still out.
So, I checked the voltage, It showed I was getting volts. So, was the bulb bad? I checked the bulb by putting it in the high beam, no problem, it works.
So, If I checked the voltage with a bulb... Now it shows no voltage.
Is this a relay problem? Where is the relay?
Old Jul 16, 2012 | 09:02 AM
LarryNH914's Avatar
This guy had the same problem. Voltage present.
Seems it is the CEM. He plugged in a new one and it worked without VADIS dealer software, so I think I will try it. I report back in a week or 2.
2000 V40 headlight issue - Troubleshooting and DIYs - 30 Forty 50
Old Nov 24, 2012 | 04:05 PM
Johnny Hamm's Avatar
Larry...would be interested in your report. The female connectors on the Volvo S-40 headlamps are crap.
Old Nov 25, 2012 | 07:58 AM
LarryNH914's Avatar
The CEM replacement fixed my problem. I got one from EBay, plugged it in, and everything was golden. No software to mess with.
It was the relay on the board. I wanted to see if I could fix the old one, tracked down a replacement relay and that one worked.
I have the CEM for sale on EBAY now.
Old Nov 25, 2012 | 08:00 AM
LarryNH914's Avatar
I should mention that replacing the relay on the CEM requires circuit board work. Desoldering a 5 pin relay and replacing it.
Old Nov 27, 2012 | 12:13 PM
Danigirl's Avatar
that is the exact problem i am having how much did you get you CEM for? i was quoted (by volvo) at almost 800?
Old Nov 28, 2012 | 08:35 AM
LarryNH914's Avatar
Default CEM cost.
I got one on EBAY for $99 shipped (used).
Shameless plug:
I do have the CEM I used while fixing my old one on EBAY now for $98. I guarantee it will work (or your money back). You have one day It is a 10 minute job to switch them (Under the dash on the left side of the driver).
3 screws and a number of plugs.
EBAY Item number 321028935068
You might get a better price at a junkyard, I have heard people got them for $75.
onebads60
Oct 15, 2014 07:48 AM
mlissmelissa
Dec 22, 2013 03:07 PM
Bilster
Oct 29, 2013 10:27 AM
jandhinalbq
Apr 11, 2012 09:51 PM
TedP
Feb 12, 2007 01:31 PM
