Heater not working
Hi all,
The change of seasons made it necessary to finally turn the heat on. But for some reason, the heater is blowing out cold air most of the time. At first it seemed like it was just taking a long time to warm up. But now, some days it doesn't EVER get warm during my 45 minute commute. Other days, it will take 10-15 minutes to get warm, but never really seems to get hot.
The fan works fine, so it's not the same issue that some others seem to have with that. And it doesn't seem to matter what the temperature is set to.
Any thoughts, ideas, or suggestions? I have to imagine somebody else has dealt with this.
It's a 2000 S40 with 186,000.
if the expansion tank was empty, there should of been a red light on the dash, you might want to put the key on second position and see if you are missing lights. Every car, and volvo i had, if your coolant tank is below the min, the light comes on, might not be on all the time, but on sharp turns, it blinks, but i could be wrong
No lights or warnings on the dash at all. The light works, and comes on when I turn the key. All of the lights work, but no indication that there was an issue with the coolant level.
Not that I'm surprised. Since I've had the car I've found a few interesting things that the previous owner(s) have done.
on
1 Post
The coolant level whilst low may have been refilling the reservoir just enough to cover the coolant level sensor as soon as the motor was started and coolant circulates, therefore not set the warning light off?
Check the reservoir for splitting and / or the cap to ensure the seal is in good condition.
Watch this and get it sorted asap as you may blow a head gasket if you allow the coolant to get too low. Not worth the risk or expense.
richardgrant
04-28-2015 08:22 PM
Sunshine2007
09-26-2012 02:14 PM
