Heater not working...
Old Jan 14, 2007 | 08:35 PM
boycebell's Avatar
Default Heater not working...
My daughter's 1994 850 Turbo's heater (fan?) just stopped working. I checked the fuses and they are ok. Any suggestions?
Thanks...Steve
Old Jan 14, 2007 | 09:29 PM
JPN's Avatar
JPN
Default RE: Heater not working...
Hello Steve,
Greetings from Chicagoland.
If the fuse is ok, it is either:
1) Fan (blower) motor itself
2) Blower resistor
Is the climate control of manual or is it automatic? If automatic, there may be some codes stored in the ECU (indicated by blinking REC & AC LED's on the panel). But even with some codes in the ECU, the climate control should work to some extent, so my guess is either of the above. Parts are pricey, but if you can do replacement by yourself, it'll at least save labour (in this particular case, Haynes manual would suffice). I replaced my blower unit and it was $139 (Behr, German) from FCP Groton. Wait to see if someone else has another idea.
Good luck,
JPN
Old Jan 15, 2007 | 03:11 AM
info2x's Avatar
If you have the MCC system and the fan doesn't work on any speeds, but both fuses are good then either something is jammed in the motor or it's burnt out and due to the high current draw the resistior is probably fried. If your fan works only on speed 4 than the resistor is bad most likely due to high current caused by an old motor with bad bearings. In both situations I would replace both components and be done with it.
If you have the ACC system listen to JPN
No matter what add a cabin air filter if your car doesn't already have one it will cut back on the crud entering your car and gumming up the motor.
[align=left] [/align]
Old Jan 15, 2007 | 09:03 PM
ORIGINAL: info2x
[align=left][/align]
+1
richardgrant
Apr 28, 2015 08:22 PM
rspi
May 15, 2014 07:36 AM
BigAdam
Oct 21, 2008 10:01 AM
desiaashik
Nov 19, 2007 08:22 AM
