Help! I screwed up my cam timing 2000 s40 1.9
Old Nov 15, 2015 | 10:26 AM
  #41
Ryanthefireman's Avatar
Default Vvt
Hi Pierremcalpine, thank you for your PM. I'm working on increasing my post count to enable my PM privileges. As soon as I can I'll message you as requested. Thank you again.
Old Nov 16, 2015 | 04:25 AM
  #42
pierremcalpine's Avatar
Just email directly at pierre_mcalpine@rogers.com
Old Oct 3, 2016 | 09:49 PM
  #43
caroleuk's Avatar
Just a couple of quick questions having read all the post's on this subject, On my car the cam sensor is facing the other way (as in on the can nearest to the front of the car) is this a problem that I should correct? (my car is a s40 1.6 2003/4)
Also is there a pdf download of the engine manual?
Many thanks (in advance)
Carole
Old Oct 4, 2016 | 09:11 AM
  #44
Carole
Hi Carole,
I don't think that's a problem. Some of the different variants have a slightly different set-up (ex: some have the VVT on the intake cam and some have it on the exhaust).
As far as engine manuals, ideally you would get your hands on a copy of VIDA which can be purchased on ebay for about $70. it is a Volvo-issued program that lists all parts, service instructions and CEL codes. you can also get a DICE reader which will team up with VIDA to allow you to communicate with the car and get additional details on CEL's + some ability to program features, reset counters, reset the service light etc. The challenge is to have an older computer nearby that will allow VIDA to run.
You can also visit Genuine Volvo Parts Online | Volvo Parts Webstore to get a good view of engine parts, etc if that helps. Just enter your car specifics and you'll see what you are up against.
Old Oct 4, 2016 | 02:19 PM
  #45
rudva's Avatar
Wink This website has great engine diagram and others
Yeah!
This is a good website with enough diagrams of the engine and others. Check it out there, before the repair manual this is my resource of parts.
Originally Posted by pierremcalpine
Hi Carole,
Old Oct 4, 2016 | 03:34 PM
  #46
caroleuk's Avatar
Thank you pierremcalpine and rudva Some great advice there
I have now ordered my parts and stripped down the areas around the head ready to do the dephaser fingers crossed that this will cure the running issues. It looks like the sensor has already been changed as I find and old one still attached to the plug and hidden under the plastic cover! (that had been disconnected so as to hind the problem from the last hapless owner - disgusting behaviour on the part of the dealer!)
So with the advice given and having read this terrible story I think I will be OK changing it.
Old Oct 5, 2016 | 01:08 PM
  #47
caroleuk's Avatar
Ok I now have a new dephaser pulley but after very close inspection it does not have a timing mark?
Now I think I'm in trouble and going to need some serious help!
Or... Can I just fit the cam (with the cam's properly locked in place) and make my own timing mark?
Any help please, I can't afford to screw this one up that's why I'm having to do it myself.
Old Oct 6, 2016 | 07:49 AM
  #48
As long as the cams are locked you can install the new vvt however you like. Just make sure that you torque it back up to spec. 80nm as I recall. Don't quote me on that though.
Old Oct 6, 2016 | 04:53 PM
  #49
caroleuk's Avatar
Thank you for that Pierre that has put my mind at rest, just need my locking tool to arrive now and it will be job done
Old Oct 22, 2016 | 06:37 PM
  #50
acfindshomes's Avatar
Ok guys, I have a 2000 S40 1.9 T. a buddy of mine took thehead off died last month and now I need to get this back together for his wife.No reference marks were left behind to use upon reassembly. I’m back togetherto the point of the cams. I have the Reluctor ring notch at 6.30 7 o’clockposition on the exhaust side. Intake cam could be 180 out. (Not sure how you know its in the proper time)Both t-belt sprockets are off and of course there are no dowel pins as referencepoints, not sure where the sprocket goes on the cam either. So I’m at a loss. Howthe heck does this thing go back together without any basic markings? FYI Ihave the proper cam tool .
Thanks in advance
Old Oct 22, 2016 | 08:29 PM
  #51
Hudini's Avatar
The cam tool is supposed to only fit one way. If you look at the cuts on the ends of the cams they are not exactly in the middle. Each cut is slightly off center. Install the cam holder tool so that it lines up with the cuts perfectly. Don't force it. The cam tool protrusions fit into the cam grooves easily.
Make sure the crank mark is lined up on the front cover. If you need to rotate the engine do it slowly so that you don't bend any valves. Once the crank is aligned and the cams are aligned you can install the cam gears to line up with the cuts in the plastic cam belt cover.
Clear as mud?
Old Oct 22, 2016 | 08:34 PM
  #52
Hudini's Avatar
Caution this is not my picture of an S40. It is to show the cam cuts being off center.
Here is the cam holder tool. Protrusions fit into cuts:
Installed:
Crank:
jmwidmer
Jul 18, 2011 05:42 PM
erndawg
Feb 13, 2009 10:14 PM
stook
Jun 21, 2005 06:24 PM
volvobacon
Apr 20, 2005 02:04 AM
