Help Major wheel/ hub problems!
Old Jan 21, 2013 | 02:10 PM
s40dawson's Avatar
Exclamation Help Major wheel/ hub problems!
hi there im new to this forum so go easy:-)
i have a 2002 Volvo s40 1.8 but i hit a kerb today at about 10mph and now my wheel seems to be bent. on further investigation i found out it was not the wheel because i tried a good wheel on that side and it still made a rubbing noise. when the vehicle is driven forwards the wheel does not run true although i know for a fact the wheel is good? i have jacked the car up and cant feel any play or see any damage. when i refit the wheel i started the car and let it tick over in 1st with the wheel off the floor and it ran true but when i let it back down is seems to be twisted somehow? could i have bent the hub?
Old Jan 21, 2013 | 03:19 PM
s40dawson's Avatar
any help at all and i would be very greatful
Old Jan 31, 2013 | 03:19 PM
01_fast_ride's Avatar
The hub and knuckle are pretty stout. Usually the weakest link in a curbing is the tie-rod. The other possibility is a bent control arm.
Old Jan 31, 2013 | 11:51 PM
MattyXXL's Avatar
You would probably get more help if this was posted in the correct forum
puxnstx
Dec 13, 2014 11:36 AM
kendogg
Oct 17, 2010 10:15 PM
csigrist
Aug 6, 2009 10:27 AM
pederoski
Sep 27, 2008 02:02 PM
lenniefoug
Aug 7, 2005 09:32 PM
