Help with seat power adjustment
Old Mar 2, 2006 | 07:48 PM
clhhunter's Avatar
Default Help with seat power adjustment
My 2000 S40 seat adjustment is slowly losing functionality.
First, the fore/aft direction adjustment on the seat cushion started working intermittently. Then, the up/down direction adjustment for the back of the cushion started having the same issue. The seat back adjustment works fine.
Has anyone else had a similar issue? How did you fix it? I took the panel and switch apart last night and think I've traced the problem to the motor. I'd like to replace it myself when I figure out the problem.
Any help is appreciated.
Old Mar 2, 2006 | 08:48 PM
Default RE: Help with seat power adjustment
Are you sure it is the motor and not the cable from the motor?
You will have to remove the seat from the car to replace the motor.
North42g
Jan 21, 2011 11:34 PM
nextproject
Nov 16, 2009 07:04 PM
marsc001
Jan 26, 2009 01:27 PM
Georgia Boy
Jul 9, 2008 01:16 PM
dpallen
Apr 2, 2008 07:09 PM
