Hood release
Old Aug 13, 2009 | 10:38 AM
slant6forever's Avatar
Default Hood release
Double wammy!!! The battery is dead and the hood release won't work. How do I manually get the hood to open for a 2002 S40?
Thanks!
Old Aug 13, 2009 | 02:23 PM
S40-808's Avatar
Is the latch inside you car broken off or something? Can you be more specific as to whats broken with it?
Usually if the latch on any car that uses a cable hood release is broken, you can go underneath the car and find an area to access the cable down there. Once you find a place all you really have to do is pull the cable till it releases the hood. For your specific car, Im not sure where that point would be. In my experience, a lot of times you are able to find a place to pull the cable towards the front of the car where the cable goes up to meet the latch.
Hope this helps.
Old Aug 13, 2009 | 04:41 PM
Not sure if it's broken anywhere. Naturally, it worked the last time I used it, don't seem to remember anything unusual at that time. This morning, pulled on the latch release under the dash and nothing happened, I can reach the cable at that point, but if it's broken somewhere down the line (or at the latch) that won't help.
And it's pretty tight under the car, with the battery dead, I can't move it (at least easily)
Old Aug 13, 2009 | 04:57 PM
S40-808's Avatar
If you feel pressure on the cable as you pull the latch it most likely isnt broken. Its a long shot, but maybe the latch itself on the front of the hood is stuck. Try and have someone constantly pull the latch over and over while you try to pull up and push down on the hood by the latch. If its stuck, this really should work.
Old Aug 14, 2009 | 08:27 PM
bigvolvo's Avatar
i have 2001 s40. when i pull from inside the car, it does not feel that the hood got opened but somebody outside needs to pull the hood up. then open the secondary lock to open the hood.
does it make sense?
Old Aug 14, 2009 | 08:52 PM
S40-808's Avatar
Well, with these cars the release lever does not "pop" the hood as with most other cars, but it is unlatched.
Old Aug 14, 2009 | 09:31 PM
850tony's Avatar
pull up on the hood as someone else pulls the release lever.
Old Dec 18, 2009 | 05:05 PM
tuco23's Avatar
so the latch on the inside of my grill of my 1999 v70 glt has come loose. is there any way to get the grill off or is there another way to open hood? thanx
MDUBBSS70
May 28, 2014 09:02 PM
jvcski
Dec 24, 2007 08:42 AM
montysano
Jul 21, 2007 09:24 AM
Lichty17
Oct 13, 2006 08:28 PM
dougsnow
Apr 22, 2006 07:07 PM
