How to clean inside of headlamp - 2005 S40
Old Dec 31, 2014 | 06:27 PM
startrek's Avatar
Default How to clean inside of headlamp - 2005 S40
It looks like water got into one of the headlamps and it's dirty inside the headlamp - probably moldy. How can I remove that an clean it? It's the front right headlamp and it's a 2005 S40 - not turbo. The headlamp has a regular bulb - not a LED. Thanks.
Old Dec 31, 2014 | 07:13 PM
pkrface's Avatar
There is no way to get in there and even if you could get it clean it would just happen again in a short period of time. Time to seek out a salvage replacement. There are multiple sellers on ebay.
Old Jan 2, 2015 | 07:35 AM
startrek's Avatar
Default Instructions for installation of headlight assembly.
Thanks! Is that easy to install? Where could I find instructions for installation? Thanks again?
Old Jan 2, 2015 | 05:01 PM
damien360's Avatar
It take less than 30 seconds to remove and install the headlight. You pull the metal pins, push the back portion out and pull the headlight towards you. Thats it
Old Jan 3, 2015 | 06:36 PM
startrek's Avatar
Thanks Damien! Do I need to disconnect the battery beforehand or anything else like that? Thanks.
Old Jan 3, 2015 | 06:42 PM
Hudini's Avatar
No need to disconnect the battery. You will need to disconnect the headlight electrical connector though. With one hand holding the housing use your other thumb to press down on the little metal bar on top of the connector while wiggling the connector until it's free.
Old Jan 5, 2015 | 07:49 PM
startrek's Avatar
Hey, thanks. It was so easy.
Old Jan 13, 2015 | 02:34 PM
mf70's Avatar
If you now have an extra headlight bucket, you can try working on the old one with the instructions from MyNameIdeasWereTaken's videos. The outer lens is held with mastic, & can be separated. Unlike the taillight assemblies, AFIK.
jgibbs
Jun 13, 2011 04:19 PM
lovethelysholm
Apr 30, 2011 01:27 PM
creamsoda
Jul 18, 2007 07:20 AM
