How to remove engine 2006 s40?
Old Nov 2, 2014 | 01:52 AM
Jtree5757's Avatar
Default How to remove engine 2006 s40?
So long story short....I have to replace engine in 2006 s40 2.4 vin 6th and 7th digits are 39.
I have alldatadiy.com subscription for this car and it has the procedure for removing the engine. However, it tells me to drop motor, lift car, and roll it out. Is this the only way or has anyone hoisted theres up and out?
Also any recommendations on a manual? I'm hesitant on just following one manual. Is just the typical hayes or chilton good manuals for this extensive work?
Old Nov 2, 2014 | 07:46 PM
mf70's Avatar
Haynes also details downwards removal. VIDA is Volvo's official manual, and you can get VMware images with VIDA installed and running for free.
Old Nov 2, 2014 | 10:45 PM
damien360's Avatar
Let me guess, it's either because of oil consumption or no compression. The reason they tell you to do it that way is because it is the easiest way to do it. Thats the way that I have done it on every engine replacement. Just take out the subframe and disconnect everything connected to the engine and trans and remove the 2 motor mounts and it comes out.
Old Nov 3, 2014 | 11:54 AM
Jtree5757's Avatar
@mf70 I'll try and check out VIDA. Thanks for checking Haynes for me!
@Damien360 Yup, oil consumption! Girlfriend ran car with little oil and now there is a hole in the block! I don't blame her entirely because her oil light never came on. But when I get it back up and running, I will be checking oil religiously.
Just to be sure, I pull engine out WITH transmission and axle, then just swap them to the new motor and then I'm good to go for the install right?
Thanks for the help
Old Nov 3, 2014 | 01:55 PM
damien360's Avatar
Yeah that's because it's a low oil pressure light not a low oil light. Well every time that I take it out I remove the engine and tranny as a whole unit , that's because I've got a lift to pick the car up of the engine. One mount holds the engine up and the other holds the trans mount.
Keith Doherty
Jul 25, 2020 03:16 PM
mightyjak
2001-2013 model year XC70
Jan 26, 2014 09:27 PM
hayseed
Jun 20, 2008 04:43 PM
lafv_5
Jan 9, 2007 09:07 PM
