How2 Fix DustFender on s40?
Old Dec 11, 2008 | 03:11 PM
posterv401's Avatar
Default How2 Fix DustFender on s40?
Hi, Thanks for your help wrt my flat tires post. I have recovered my s40 from the shop with V tires. But the shop
didn't fix the dust fender(dustguard?) under the two passangers doorside. They did successfully repaired the dust fender on the back wheel side. By dustfender, I mean the plastic black rail(?) on the bottom edges of the car. The dustfender is still loose under the passanger door. can I glue them together using plumber epoxy? How much will a volvo dealer charged? It's a 10 year old s40, is it worth getting a volvo dealer to fix it or simply paste it back using plumber epoxy?
Are original S40 wheels/rims made of aluminum? what does it mean by I have to retorque aluminum rims/wheels after 25 miles?
thanks. posterv401
Old Dec 11, 2008 | 06:03 PM
Default RE: How2 Fix DustFender on s40?
You might only need new clips to secure the panel. Take a look and see if the clips broke.
Yes the original rims are aluminum. The S40's had a slight problem with the lugs coming loose at times. I would double check to make sure they are tight.
drenman
Nov 29, 2016 07:35 AM
snowborder142190
Jun 6, 2015 02:49 PM
jl227
North East
Sep 27, 2010 10:09 AM
theotherpilot
Jul 10, 2009 12:28 AM
Volvorator
Mar 15, 2007 10:37 AM
