I need hep with my window!
Hi all! I have a 2002 S40. My drivers window started to make noise a while ago when i was raising it! It sounded like a gear stripping. Now if i put the window down I actually have to grab the window by hand and pull it up while I am pushing the window button. And the whole time it sounds like gears stripping. Does not do it going down! What do i need to do here! I am afraid at some point it will not come up! Car has only 92k on it!
You need a new window regulator. It's part number #30623448 on RockAuto Auto Parts
Price is $179.36 and it shouldn't be too hard installing it yourself
Motor & Regulator
1. Place window in fully raised position.
2. Disconnect the negative battery cable.
3. Remove or disconnect the following:
-Inside door handle
-Cover at base of door mirror
-Screws holding door panel
-Pull off door panel
-Electrical connectors at switch module
-Cable for the inside door handle
-Guide molding
-Guide rail
4. Secure the window using tape to keep window in raised position.
NOTE: The lift mechanism is correctly positioned for removal when the holes in the mechanism and in the arm are opposite each other.
5. Remove or disconnect the following:
-The rivets holding the lift mechanism
-The lift mechanism
-The connectors for the power window motor and regulator
-The rivets holding the motor in place
-The motor and regulator
To install:
1. Install or connect the following:
-The motor and regulator into position. Install new rivets
-The lift mechanism. Install new rivets
-The soundproofing
2. Install or connect the following:
-Connect the connectors to the door module switches and power mirror switch
-Guide rail
-New rivets for the guide rail
-Guide molding
-Press door panel into place
-The M6 screws. Tighten to 88 inch lbs. (10 Nm)
-Cover at the base of the door mirror
-Door handle
-Negative battery cable
Motor & Regulator
-Inside door handle
-Guide molding
-Guide rail
-The lift mechanism
To install:
-The soundproofing
-Guide rail
-Guide molding
-Door handle
850GLTWAGON
11-21-2008 04:14 PM
