Idle Control Valve
Old Feb 17, 2019 | 05:29 PM
Zippy83's Avatar
Default Idle Control Valve
Hi.. I am suspecting a bad Idle Control Valve, but having issues finding if my 2006 s40 2.4i has one or not..
Does anyone know if it does and where the location might be?
Thanks
Old Feb 17, 2019 | 08:45 PM
ES6T's Avatar
It does not.
Old Feb 17, 2019 | 09:43 PM
Zippy83's Avatar
Originally Posted by ES6T
It does not.
so how is the idle controlled then?
Old Feb 18, 2019 | 12:08 AM
ES6T's Avatar
With the electronic throttle. There is no throttle cable connecting the pedal to the throttle. It's all done electronically.
Old Feb 18, 2019 | 08:31 AM
Zippy83's Avatar
hmmm interesting. My RPM’s when in idle should be right at 800 but those are between 600 and 700. I wonder what could be going on there.
Old Feb 18, 2019 | 04:23 PM
did you test for any intake air leaks? Its possible the ETM (electronic throttle mechanism) has some issues - you can read up by googling "Volvo ETM symptoms" - there are services which will rebuild plus you can find kits to replace the contacts which fail most often. See if the ARD Ideas web site still offers the kit.
Old Feb 18, 2019 | 05:23 PM
Zippy83's Avatar
Did smoke test came back negative.. I also got a new Throttle body, it behaves the same way as the old one.
Grey Bearded One
2001-2013 model year V70
16
Nov 5, 2015 01:40 PM
roberius
Jan 11, 2009 08:45 AM
Praba8890
Oct 8, 2008 09:04 PM
montysano
Mar 11, 2007 02:06 PM
dtupac
Nov 20, 2006 03:41 PM
