Immobilizer
Old Nov 13, 2006 | 04:06 PM
jabbo's Avatar
Default Immobilizer
I'm having intermittent problems with the immobillizer on my '01 S40. Three questions: Will a battery that's about to go bad cause that? How does the immobilizer work? Can the immobilizer be disabled?
As always, many thanks.
Old Nov 14, 2006 | 08:48 PM
Default RE: Immobilizer
Yes a bad battery will cause that.
No the immoblizer cannot be disconnected.
Old Nov 14, 2006 | 10:59 PM
jabbo's Avatar
Bad battery it is...battery died yesterday morning, I replaced it and haven't had any problems with the immobilizer since. Immobilizer kicked in maybe 50% of the time before that.
Many thanks!
Old Dec 24, 2006 | 06:09 PM
Volvonut's Avatar
You say the immobilizer kicked in, I assume that means the car wouldn't start (would doors open?) but what did you do to get it to start until you replaced the battery?
Old Dec 27, 2006 | 09:24 PM
jabbo's Avatar
I would just try several times (maybe up to seven or eight times) and it would eventually start. I don't know about the doors - I didn't try to get out before the car finally started. After the battery died I wondered if it was the problem - apparently it was since I still haven't had any problems.
KREID
Jun 23, 2021 02:37 PM
kkboyvolvo
Feb 14, 2009 04:00 PM
yousefkali32825
Sep 23, 2006 07:31 PM
benbtj
Apr 9, 2006 04:55 PM
gmyoryi
Nov 19, 2004 09:49 AM
