Inner Sway bar bushing replacement
Old Apr 5, 2013 | 10:19 AM
kmgar99's Avatar
Default Inner Sway bar bushing replacement
Has anyone changed the inner sway bar bushings on a 04 1.9L? I can't figure out how to get to them?
Old Apr 5, 2013 | 09:59 PM
Hudini's Avatar
I believe I used a short 1/4" drive ratchet with a deep well 10 mm socket. Any similar combo that allows you to reach over the bushing but does not stick up too high and hit the bottom of the body. You will only get a click or two on the bolt so patience is key. When replacing be careful not to cross-thread the bolt. I boogered mine but good on the passenger side. Went in at an angle but is still holding.
Old Apr 5, 2013 | 10:25 PM
ES6T's Avatar
Was that for the P1, Hudini? I don't think there is a way to do them on the 1.9L without lowering the subframe.
Old Apr 6, 2013 | 07:31 AM
Hudini's Avatar
It was on my 2001. It was a PITA but I did both sides. Lowering the subframe might have been easier, I don't know as I've never tried that. Just a tiny bit more room would make a big difference though.
Old Apr 6, 2013 | 08:50 AM
kmgar99's Avatar
I cant get a wrench or socket on the bolt. I know i'll need to lower the subframe...anyone every lower the subframe before? I think i know where all the bolts are, just wondering if i should be aware of anything i cant see.
BTW i have an 04 S40 lse nedcar
Old Apr 7, 2013 | 09:12 AM
Hudini's Avatar
Let us know how it goes. Sure would be nice if there were an easier way.
Old Apr 7, 2013 | 10:51 AM
kmgar99's Avatar
Frustrating! I can see the bolt head and touch it, just need another 1/4" of space and i could get a socket on it! ARRGG!
Old Apr 11, 2013 | 08:42 PM
ppap's Avatar
Its been a while since I did one of these but I ended up lowering the subframe. I had access to a lift and was able to use a pogo jack to support the subframe as it lowered. Took less than a minute and gave full access to the sway bar.
Old Feb 28, 2017 | 11:40 AM
s40200's Avatar
This was on a S40??
I have a 2001 s40 with a bad bushing and its clunking.
Is ot only the 1 bolt near fire wall.
urdrwho
Nov 23, 2014 09:49 PM
artbar92706
Mar 4, 2013 08:34 PM
dsniner
Jun 17, 2012 12:18 PM
Tech2Tex
Sep 25, 2011 06:45 PM
crosby1
Apr 11, 2011 09:44 PM
