Instrument's lights on 2000 s40
Old Jul 15, 2009 | 02:39 PM
mel0106's Avatar
Default Instrument's lights on 2000 s40
I have a 2000 s40 and the instruments lights are not working on the temperature, and air control ****. It's very difficult to find the setting when driving at night. The dealer estimate was around $250.00 which will include changing all 3 bulbs inside. I just can't justify paying that much money for a burn out bulb. Does anybody know or has someone experience changing the bulbs yourself. I consider myself mechanically inclined but would like to know where to begin. Any thought or help is greatly appreciated.
Old Jul 15, 2009 | 07:02 PM
850tony's Avatar
for the temp light you need to remove the instrument panel to replace the bulb from the back.
same for the control ****, the ecc needs to come out.
Old Jul 15, 2009 | 09:44 PM
nattyderek's Avatar
Can you elaborate a little. Is this a reasonable DIY project ? I have the same problem with the climate control bulbs.
Old Jul 16, 2009 | 11:53 AM
850tony's Avatar
sure u can diy it, most do, but it is kinda in depth for some.
for the gauge lights:
Remove two bolts from the steering column mounting and lower column.
-Remove two self-tapping screws from trim edge and press edge downwards out of clips.
-Remove three self-tapping screws which hold combined instrument panel and remove it (connectors and cable are behind in dashboard).
Pull first straight outwards.
for the climate:
Make a note of the radio code
-Switch off the ignition
-Disconnect the battery ground lead
-Remove the radio
-Disconnect the connectors
-Remove the storage compartment in the centre console.
Removing the front panel
-1: Press up the catches behind the holes in the front panel
-2: At the same time pull the lower section of the panel towards you. (Use a weatherstrip tool.)
-3: Press the whole panel upwards slightly. Pull it towards you from the top. (The controls remain on the heater control panel.).
Removing the control module
-Remove the 3 screws
-Removing the control panel.
Old Jul 16, 2009 | 01:07 PM
mel0106's Avatar
Thanks for taking the time to explain it. I really appreciate it.
Old Jul 16, 2009 | 03:07 PM
nattyderek's Avatar
This is great info. Thanks a lot !
Old Jul 16, 2009 | 10:20 PM
850tony's Avatar
anytime
jpjmustang
Apr 24, 2014 05:35 PM
ctharley
Mar 15, 2007 04:23 PM
thegor
Jan 28, 2007 10:33 AM
krisby
Mar 24, 2006 11:58 PM
