K&N filter in S40 T5
Old Feb 9, 2023 | 11:31 AM
JAV_W's Avatar
Default K&N filter in S40 T5
Any eperience using K&N filters in S40 T5?
Wondering if the turbo will support it.
If not, experience using high quality aftermarket filters such as BMC or AEM?
Thanks
Old Feb 9, 2023 | 11:53 AM
habbyguy's Avatar
I had an Acura MDX, and it wasn't getting quite the mileage I thought it should. I went through quite a few parts chasing the missing efficiency (which translates into missing horsepower). Finally tossed the K&N air filter element that the PO had installed, and put in a paper element. Instantly got my MPG back.
Worse, if you're looking at one of those goofy cone filters that float around in the engine compartment, you'll be making LESS horsepower and reducing your MPG. The stock airbox breathes better than anything you're going to buy on the aftermarket without paying a fortune / cutting new holes in sheet metal.
Old Feb 9, 2023 | 01:55 PM
Dingus1's Avatar
I used the lifetime oil-less high flow air filter from IPD on my S60 and it made cute turbo noises Just blew it out with air every oil change.
And yeah like habbyguy said, dont do the hot air intake mod
Old Feb 9, 2023 | 05:19 PM
not a fan of KN for cars with a MAF. KNs use a wet filter that can lead to some of the oil getting on the MAF. Volvo factory airboxes are pretty good stock so why change from a paper filter? Days of getting HP from a different air filter was back when moms were driving Buicks with a carb...
Old Feb 11, 2023 | 08:40 PM
JAV_W's Avatar
Default No K&N air filter then.
Thanks all for your replies. I'll continue using the OEM air filter, as I donīt want to deal with further engine problems. This model's engine is very picky so far.
marcm1
Jan 3, 2022 03:15 PM
salgoud07
Apr 16, 2015 07:38 AM
Bluemorty333
Jun 4, 2010 01:33 AM
PDMS60
Jan 14, 2010 01:23 PM
