misfire
Old Jul 12, 2010 | 08:52 AM
darimik's Avatar
Default misfire
Hello,
I have a P0302 code.
However after switching the wires cylinder 2 and 1, resetting the code, I still get a P0302 after a while. Usually the cars starts rough in the morning (when its colder), but then its fine after 2 minutes.
any ideas of what could be the problem ?
Thank you
Old Jul 12, 2010 | 04:12 PM
GerBeGurGya's Avatar
Still could be the coil or the plug itself.What year is it and when did you replaced these items if ever?
Old Jul 12, 2010 | 06:00 PM
darimik's Avatar
I dont think the coil was ever replaced. However, if I switched the coils including the wires, wouldnt that change the cylinder number if it was bad ?
2001 Volvo S40
Old Jul 12, 2010 | 08:37 PM
2001 Volvo S40
Yes it would have that is why I did ask.Now you only mentioned that you swithed the wires I thought you didnt switch the coils.If you did then the answer is obvious.Change the plugs but all of them.Get nothing cheaper than OEM platinum's.
rmmagow
Aug 23, 2006 10:57 PM
Jul 28, 2006 04:14 AM
JIMMY
Mar 31, 2006 09:44 PM
hwy9rnr
Feb 22, 2005 10:54 AM
