My 1st S40... just bought a 2001
Old May 8, 2015 | 09:43 PM
  #21
migbro's Avatar
Good job.
I've been thinking about why my older Toyotas require so much less maintenance than other cars I own like Volvo and VW and I think it boils down to a philosophy of simple design. If the design feature is absent you won't need to maintain it.
For example, my V40 has a bit of a start-up rattle and I think the reason is probably the oil pan o-rings, another unnecessarily complicated design feature.
So I'm thinking about doing my turbo oil return pipe seals soon and that project is now expanding to include oil pan o-rings, engine mounts and maybe a drive axle.
Old May 11, 2015 | 12:31 PM
  #22
malcolm2's Avatar
I get a rattle too. Goes away by the time I am out of the driveway. Never heard of "oil pan o-rings" tho. Can you help me out with what you are referring to?
During the turbo drain tube thing, you have to (or should) remove 2 mounts. Both of mine were slightly broken, so I got the rear one from AutoZone and front from the JY. It will probably go soon but it was better than mine and AZ only had the one and I was at the Yard anyway. PO had bent the sway brace.
On my continued oil leak, I started a new thread. But had to remove the air box, battery, and other stuff on that side to find that the cam position sensor cover was were the massive oil leak is coming from.
Anyway, the motor mount, under the air box is really bad. Wish I had one of those. Next order, I guess.
colt1911a
May 10, 2010 06:39 PM
edtrash
Apr 10, 2008 02:42 PM
850ROwner
Jun 7, 2007 10:27 AM
richsid
Jun 21, 2006 02:18 PM
Wask
Jun 7, 2006 02:28 PM
