my s40 1.9 t won't start
my 2000 s40 won't start. it turns over but won't start. it had a crack radiator and I replaced it with a new one and new thermostat.I check park and fuel and their ok but it won't start.I chance spark plugs coils, and crank position sensor and still won't start. timing belt is ok.I need help please.
I checked the fuel pressure and it's@ 45 psi. the fuss are ok and I tried starting out with the throttle open just a bit and still won't start. could it be the fuel pump or the regulator.
yes I get spark to the cables and the car did overheat.I do hear the fuel pump running and I did try the starter fluid. I'm running out of options. don't know what else to try. thanx for your help.
You said that, you changed the crank position sensor, was that due to a code, or you just assumed its bad. I would check the compression as well, since the car gets fuel and spark. If you really trying to fix the car yourself, the best guy to ask is Hudini, that guy is like a volvo owners manuel.
Fuel pressure is low. Most likely the fuel pressure regulator.
Having written that, my 2001 suddenly quit while my daughter was driving it. It restarted once enough to get it off the road but would not fire after that. When I checked the fuel pressure it was zero. Guess who got to change a $305 fuel pump ASSEMBLY? We don't just have a simple pump; we get a pump, level sending unit, and plastic sump housing all in one expensive setup. Yay. At least it was easy to access under the rear seats and carpet.
hokiedave
05-04-2009 12:37 PM
Dialler150
04-11-2007 03:58 AM
