Need advice on how to remove oil pan
Old Feb 24, 2009 | 02:54 AM
JZA1979's Avatar
Default Need advice on how to remove oil pan
ok, i've got all the bolts out except 2 of them that are between the oil pan and the subframe. My question is this. Can I use a jack to support the motor and then remove the motor mount bolt and then the 2 bolts for the subframe in the front? Or will I have to remove the entire subframe? Will I need to use a cherry picker or engine hoist or will a jack suffice? I just need the subframe to drop about 2-3 inches to back those 2 bolts out so i can get the oil pan off. Are there any other bolts/parts i need to remove to get the oil pan out? I removed the oil cooler already too.
Thanks!!!
Justin
Old Feb 24, 2009 | 06:35 PM
If it is a 2000-early 2004 then you can remove the cross member and not worry. There is 4 mounts total 2 upper and 2 lower.
Old Feb 25, 2009 | 02:24 AM
JZA1979's Avatar
its a 2001 1.9T
Old Feb 25, 2009 | 07:12 PM
Then you will not need to support the motor the top mounts will hold the motor.
It will just sway some which is fine.
Old Feb 25, 2009 | 08:29 PM
JZA1979's Avatar
Thanks for your help!
I'm helping my brother because he cracked his oil pan. I was going to take it off and weld it for him and you just saved him a ton of money cuz I thought he might have to take it in because I do'nt have a cherry picker.
Old Feb 25, 2009 | 08:44 PM
Nope there is a motor mount on the front of the motor and one on the top of the tranny.
Remove the lower bar with the 2 lower mounts and the motor will hang with no problem.
jamieheath
Apr 13, 2022 12:13 AM
svg1234
Volvo C30
29
May 15, 2013 08:27 PM
mercb
Dec 11, 2009 01:49 PM
Keith Tobberman
Nov 26, 2007 12:35 PM
