Need radio code
Old Feb 12, 2009 | 07:42 AM
rpomerle's Avatar
Default Need radio code
Hello- The incorrect code has been entered in the radio. Car is 2001 S40. What I need to do is remove the radio to get the serial and model #. Does anyone have any help on removing this radio. Thanks
Old Feb 12, 2009 | 11:21 PM
jrgillespie630's Avatar
From: Cincinnati, but somehow ended up in Milwaukee
well if it's like my 04 first generation there should be two little tabs one in the middle of the radio on each side, push those in and they should pop out and then you can pull the radio out. once you get the numbers off of it chances are a stealer will make you take it to them to prove it's actually in YOUR car and then can give you the code for free.
Old Feb 13, 2009 | 07:28 AM
Lyonsroar's Avatar
What's up?
I gave you all the advice you needed on your other thread.
It's really easy, honest!
And I believe the dealer asks for the VIN number as well to get the radio code. I warned you about this on your other thread.
Calyn
Jan 3, 2013 06:50 AM
luvmybassetthound
Jun 30, 2008 06:04 PM
cbgav
Sep 10, 2007 05:25 PM
